schmack b
- Location
- Clarksdale, MS
- BigRock 4x4
- Granite
- Kraton 6s
- Mojave
- Outcast 4s
- Typhon 3s
The esc in my granite BLX keeps randomly cutting out. Sometimes its last for just a second, and sometimes it last as long as twenty seconds. When it happens, the brake tone comes from the motor, and I'm pretty sure the entire esc shuts off and comes back on. I have torn the truck apart and replaced the bearings, so I'm confident everything is good(except to tight gear mesh)in the driveline.
I have also bench tested the wiring by pulling the crap out of them and it doesn't seem to be a loose connection anywhere. Also sometimes it cuts off completely, and as soon as I get to the truck and touch it, it comes back on. After that as soon as I touch the throttle, it cuts off again. It does this a few times until it finally stays on after a couple attempts. Then I can run fine for about 5 more minutes, and it starts doing it again.
It does not seem to be a temp issue as the motor is at about 100 and esc at about 75 every time I check it when it starts happening. It also does it with 2 different batteries.
Anybody got any ideas. Thanks.
