On Crawlers alu,. looks sweet bare. But it's a different animal, low gearing and all.
I find that old steel toolbox material also looks sweet. My Wraith (sold it to partially finance my Kraton):
$91.72 per box $4.79 a square foot comes in a box that covers 19.15 square feet.
Last night I was able to find a 24x12 sheet of lexan for like $12, and I'm sure I could find diamond plate vinyl as like you all said it would look bad ass.
I'll do some searching around and see what I can find.
Looking go so far John.What the vibe going to be? I would think some diamond plate would be bad ass.
I wanted to try and keep it as light as possible. The Lexan is working great, just forming it is a bit tricky and new to me, I already melted one piece pretty bad.@slick2500 Any reason for not using aluminum?
Are you using any kind of form to mold the lexan to?I wanted to try and keep it as light as possible. The Lexan is working great, just forming it is a bit tricky and new to me, I already melted one piece pretty bad.
I made one for the hood, the roof I just left flat. I'm going to have to get creative for the one for the sides.Are you using any kind of form to mold the lexan to?
No sir I do not.Got access to a printer? The panels should be easy to model since they're flat and diamond plate embossing could be extruded on the surface. I could do one up if you got me some measurements
Yeah the first side panels I made I was able to get them to bend and conform to the cage by heating them up with a hair dryer it took forever though. I am pretty sure I don't want to use the heat gun on or near the cage. The lexan I bought is only 1.6mm thick.If you want the side panels to hug the cage you'll need a couple of bends in them. The bends are not perpendicular to the center line of the body.
Maybe lexan is flexible enough to conform to the cage without bends? I don't know since I've not worked with lexan beyond painting it.
How are your woodworking skills?No sir I do not.
If you tried to just lay kydex against the cage and heat it with a heat gun you would deform the cage very badly.I bet Kydex would be perfect for this.. You'd just make oversized panels and heat the edges and curl them around the frame.
Just okay.How are your woodworking skills?
Make a form out of a 2x4 and then go to town with the heat gun.
The extra benefit to having the form is for making panels in the future.
Kydex really needs to be molded around a form that won't deform from heat.
With a saw, rasp, sandpaper and patience it'll be pretty straightforward.Just okay.
I've built a house, a garden shed, some cabinets, a clock, a shelf, an entertainment center and a desk.
I'm sure I can whip up something with a jigsaw.
