RackwitzG
Hello,
I wanted to set my brakes to 75 % on my Granite V3. I pressed and held the set button, turned the power on, let it beep green 3 times for the variable "Brake Strength" and let go of the set button. Then it beeped red 4 times to signal the default setting 4 (62,5%). Then I pressed the set button again, hoping it would move to 5 beeps (75%), which is what I wanted, but it beeped and flashed once, obviously going back to step one. I went through the process a few times and had the same results, couldn't get passed setting 4. Einstein said, it's stupid to do the same thing several times and expect different results, but he didn't know computer electronics then. Einstein was right this time though, the same thing happened every time. I just can't get past setting 4. According to the manual there should be 7 settings! What can I do? I can imagine the manual is not up to date? Eventhough I got it with the truck.
