Adamator
Hey all
Had a bit of bad luck with my Granite the last few weeks. Started with my rear diff. I had to replace it as a screw got stripped that connects the driveshaft and I couldn't recover it. Got a replacement from Jenny's RC. Although what happened might have been avoided, it was a good experience in that it got me kind of familiar with accessing the Diffs.
Then I managed to crack the slipper set and stripped another spur gear. I replaced the slipper set and took the opportunity to upgrade to a metal spur gear.
Weather has been bad here, so I had not used my Granite in days. But I had a chance today to take it to my favorite spot, a BMX Park. It was the first time I had ran it since replacing the Diff, slipper set, and upgrading to the metal spur gear. Almost immediately I knew something was up as when I gunned the throttle, I had almost no power. Still being only a few months into this hobby, I wasn't entirely sure what was going on but I was pretty sure I could hear the slipper. I took my truck back to my car (I had brought my tools thankfully) and adjusted my slipper. (I adjusted it based on the popular method that floats around on this site.) That seemed to fix things and I had a good run for almost all of my 5000 mAH 3S Lipo. I was mostly just doing laps on the rc track that is there. Near the end the same problem seemed to return but this time much worse. I had almost no rear power at all.
https://share.icloud.com/photos/0yyGYpduIrrSgLXfpRAG5UNyg
I wasn't sure what was wrong this time but decided to just pack it in and head home. Later took things apart and found I had indeed stripped out my first Input Gear. Based on how often I hear these break, I have been fortunate that this is my first one and I got the truck at the beginning of June.
Getting to the point of my post. In taking my Diff out and inspecting it, I noticed something on the exploded diagram I had somehow missed before. There is (I think) a shim on the outside of the diff case, part AR709052.
I don't have that piece on my diff and if I did, it's long gone unfortunately. (Or if it's still on there, I definitely do not see it.) I wanted to ask how important that shim is? and could it missing be what caused me to strip my first Input Gear after all these months?
If not, what are some other common things that cause them and how can I (Hopefully) avoid it?
Thank you.
Thank you.
