Hello, I know this topic has been bashed to death. I'm pretty new to this and have grown tired of replacing my stock motor that burns out when you look at it. I've tried running 2s lipos and even the stock NiMH batteries with the same results. I have just purchased a brushless system from HobbyKing, the system is:
ESC Specs:
Continuous Current: 80A
Burst Current: 95A
Resistance: 0.0009ohm
Battery: 2 cells Lipo (5-6 cells NI-xx)
BEC output: 6V/1A
Motor type: Sensorless brushless motors
Running mode: Forward only or forward with reverse (user programmable mode)
Dimension: 43 x 38 x 20mm
Weight: 88g
Motor Specs:
Model: 3650 Sensorless
Kv: 4000
No. of Poles: 2
Cont Current: 45A
Peak Current: 55A
Max Power (15sec): 370W
Winding: 16T
Resistance: 0.0125ohm
Weight: 180g
Diameter: 36mm
Length: 53mm
Shaft Diameter: 3.175mm
Includes:
80A Sensorless Brushless ESC
3650 16T (4000Kv) Brushless Motor
Will this be a plug and play system using 2s LiPO batteries or do I need to upgrade some driveline items? Please talk (type) slowly as I absorb the information given to me...LOL.
Darren
ESC Specs:
Burst Current: 95A
BEC output: 6V/1A
Weight: 88g
Motor Specs:
Kv: 4000
No. of Poles: 2
Cont Current: 45A
Peak Current: 55A
Winding: 16T
Weight: 180g
Diameter: 36mm
Length: 53mm
Includes:
Darren
