First, some planning:
Motor & ESC:
Keep stock components until not serviceable.
Failure will be an opportunity for improvement.
Receiver & Transmitter:
Primary goals are improved range and adjustable throttle endpoint.
Dumbo RC combo has been an effective and affordable solution.
The stock radio does offer some control for throttle limiting, but I prefer more adjustability.
Servo:
Plan for early failure of stock servo, but enjoy it while it lasts.
Savox SW1210SG-BE ready for duty.
Servo Mount:
Action is required here. Wow does the stock mount flex.
Will try M3x30mm screws before selecting an aluminum upgrade.
Servo Saver:
Action is required here. The stock servo saver configuration does not provide adequate steering authority.
Extra hard spring (used in EXB) + circlips / shims (In Progress)
Chassis Braces:
M2C front chassis brace (Completed)
M2C rear chassis brace
M2C rear shock tower brace
Shock Towers:
M2C rear shock tower (EXB/V5). Seems to be a common weak point.
Stock front shock tower - until failure
Chassis:
M2C
Differentials:
Open & inspect. Shim if necessary.
Replace gaskets with Tekjo
Run stock weight fluid.
Battery:
Currently running a 4S battery from another rig. Great way to get a feel for this new platform.
Planning to run a 6S battery, with punch turned down and perhaps some throttle limiting depending upon operating conditions.
Motor & ESC:
Servo:
Servo Mount:
Servo Saver:
Chassis Braces:
Shock Towers:
Chassis:
M2C
Differentials:
Battery:
