+1.
100% normal where the St trim is or anywhere on the dial, so it "Drives straight". You probably need a wheel alignment/ ST tie rods may be off center if not the Servo arm. Out the box they all suck. Also if you struck something hard enough, the steeing gets tweaked, and needs to be dialed straight. Sometimes the Ackerman plate will bend with impacts and affects the steering trim as well as endpoints. Check well for bending. It is hidden and not in plain view under the Top plate. It can be hammered straight/flat again, if you remove it. Or just upgrade to a harder 7075 alloy one.
I hope you absolutely adjusted your Steering Endpoints well. Very important, or risk trashing the servo. The stocker ones suck anyway. But usually last better in the On road platforms if setup properly.
