Notorious change the original rear and front Center Chassis with EXB components?
Matschik2023
Hallo, it is hassle-free to change the original rear and front Center Chassis with EXB components?
I mean have the EXB components have exactly the same dimensions as the original components?
Regards - Martin
If you choose the correct crossover Arrma Optional EXB Part numbers, there is no reason why they will NOT fit and replace the Arrma OE ones !
I don't quite understand your question there??????:rolleyes:
Regards - Martin
Hi Martin
Yes you can swap out standard parts for EXB components no issue
