The very first thing to do on the transmitter is set channel 2 (assuming your ESC is connected here) from NOR to REV. Then hold the set button and power on the ESC. The rest of the instructions are in the arrma manual. I think is something like, transmitter on, then power on ESC with set button held down, release set button after beeps. With transmitter in the neutral, the ESC beeps and flashes green, then pull full throttle and hit set button again, ESC beeps and flashes green. Pull full brake and press set on the ESC, beeps, green flash and your done. Power off ESC.I have a Kraton 4S with the stock servo and radio. I'd like to change out the radio controller and receiver to a different one. Will I need to reprogram the stock ESC? If so, does anyone know how to do it?
Thank you
