Jonjon0389
Okay so here is the issue.
I I'm running a Castle Creations 1515 motor with the mamba x8s. I have a fireteam center to set up. Then I have Creighton front and back diffs. I'm running a 18 tooth pinion with the whatever it comes on the Center Drive for a fire team. I've got Proline Badlands I think they're bad ones tires the monster truck tires. I've got the m2c Italian XL beef kit on it the extra large one. I've got upgraded dog bones Center Drive bones, RPM arms front and back, fast Eddie bearings throughout. The issue I'm having is I had to just lower from a 20 tooth pinion because the motor kept overheating every like seven or eight minutes and it cut off. Oh yeah I'm running the basher batteries 120c 6800 mAh. So I went down to an 18 tooth because it was overheating and I had to go down to a 15 tooth because it was still overheating but the issue I'm having now is is the diffs the little pin in the diffs snap left and right the front one will break I'll replace it as soon as I replace it the back window break I've probably been through seven pins in the last week and I haven't driven the car more than an hour does anyone have any ideas
