I'm still fairly new to RC, and I just received my first ever Dremel. I got the Dremel 4300, which came with a starter set of accessories. But a quick search shows me that there is a whole world of accessories that I could get.
My first Dremel project will be to cut wheel notches to help with my hex nut damaging my Kraton 6s's wheel hub. I need to cut two things: the plastic of the wheel hub, and the longer hardened steel pins that I purchased to replace the ARRMA AR713009.
Stock 2.5mm wheel pins:
2.5mm Steel Rods I need to cut down to about 30mm in length.
The area of the hub where I will cut the notches. (pic source)
Here is what came in my Dremel kit:
My Questions:
1) Which Dremel accessory is best for cutting plastic?
2) What other Dremel accessories are good for general RC stuff?
Thanks!
My Questions:
Thanks!
