My old tires in the granite keep getting unglued and are starting to rip at the rims. In order to reduce ballooning and not not having to deal with glue I bought a set of Duratrax MT 2.8 Belted tires, 14mm hex.
https://www.horizonhobby.com/produc...MIpLP49q3J_wIVvAutBh3wgwdDEAQYAiABEgKG7fD_BwE
The wheels appear to be beadlock, and being belted there should be less balooning.
The issue is that these tires are huge! They are about 1" larger in diameter than the older non belted tires. While both types of wheel are rated 2.8" the beadlock rims are over 3" to make space to clear the screws that hold the tire.
Will these tires work on the Granite 3S blx with the stock 15T pinion and stock plastic gears? Or will they destroy the drivetrain or heat up the electronics?
