- BigRock 4x4
- Kraton 8S
- Kraton 4s
- Nero
- Outcast 6s
- Outcast 4s
- Typhon 3s
Ran my Bigrock last Saturday at the soccer field for about 5 min tops. Hit a couple of jumps and did a short burst up and down the field until it tumbled and died...sort of.
I noticed I lost response from the transmitter almost immediately. Figured the battery must've come loose. When I walked up to it, I could hear the fans cycling on and off. The ESC will flash once then turn off, then on repeatedly until I switched it off. I thought the battery was bad ( acquired used) , but I was wrong. Same battery worked fine in my Typhon. I tired a second battery with no luck.
Was thinking a broken wire but that doesn't seem to be the issue either.
I tried a search and found one topic on power cycling. Didn't see a clear answer in that old thread so I figured I ask here.
Is this a sign that my ESC is toast or is there something else that's causing the ESC to cycle like it is.
