TyphoonS3
Hello guys I've recently just getting into the ESC tuning it's pretty neat but it obviously allows you to destroy your vehicle 10 times as fast. My punch setting goes up to 9, which all I want to do is backflips on the takeoff, I think the punch is the acceleration. The motor timing/degree I believe the lower it is the longer it takes in for the power to kick in. Does anyone have a good recommendation on punch settings to motor timing degree ratio? In just one more weird question why would you want to change your running mode where there's Forward and brake only or Forward brake and reverse, why would you want to take reverse away? Thanks guys I appreciate your time and by the way don't ever set your break strength too strong because when you're coming in hot and hit your brakes you may just do a front flip and take someone out.
