Senton Fan upgrade question
RCpower
Hi, can I connect a 50mm kraton heatsink fan in a senton 3s with the original connector?
I bought a gpm upgrade and the fan blades broke. I see that the arrma kraton 8s is the same size 50mm.
Thanks, here is the problem. I upgrade to gpm fan and only works for 1 test run. I don't know why the blades broke because i have a dusty covers shield. And no rocks or debris were inside the car. Maybe broke with some jumps. Im looking to upgrade with the 8s kraton because have the same dimensions 50mm
Anywan knows what is the voltage of the katon 8s fan?
I'd guess like most stock fans they are 7.4v -8.4v. And fan probably broke from impact of jumping causing it to bounce up and down and catch blades on heatsink or on the cover.
