Kraton, Talion and Outcast/Notorious can all use the front cvds in the rear, you do have to limit your suspension down travel so that the bone end doesn't bind in the drive cup.Has anyone tried putting the front CVD's in the rear to replace the dog bones? Did some searching no luck. Found a thread on I believe the Kraton putting front CVD in the rear.
Yeah, I’ve done that on a Typhon, with the Durango driveshaft, which shouldn’t matter.Can the same be done with the Typhon V4?
