Jeremy20081
Im putting Inner diameter: 3.8" (96mm) | outer Diameter: 6.5" (165mm) | width: 4.1" (104mm) | Hex size: 17mm | offset: 0.5" (12mm) duratrax lock ups the factory tires are bead diameter: 4.13" (105mm) Width: 2.24" (57mm) Wheel hex size: 17mm Overall diameter: 5.75" (146mm) I did a RC gear ratios calculator an to get back to stock gear ratio I need to put a 66 tooth spur gear on it. I want to make sure this is possible an am I looking at this right.
