FireDrake001
- Typhon Mega
I put my spare stock XMaxx motor in my Mojave. I’m wondering what gearing should I do? It’ll only be running 6s.
That's a 1275kv motor, it's really similar in power to the 1260kv Castle motor, you can safely start at 19 or 20 on the pinion... starts to get really fast at the 22-25 range, that's actually a pretty good motor imoI put my spare stock XMaxx motor in my Mojave. I’m wondering what gearing should I do? It’ll only be running 6s.
Ok. The other guy said the tires won’t handle it. I’m not looking for anything above the rtr performance. I already have a 18 tooth in it. I was only gonna run it ever on 6sThat's a 1275kv motor, it's really similar in power to the 1260kv Castle motor, you can safely start at 19 or 20 on the pinion... starts to get really fast at the 22-25 range, that's actually a pretty good motor imo
The tires will hold... give the glue a quick check, tape over the vent holes in the wheels, and vent the tires in 2 spots 180° apart... then beat that thing like it owes you moneyOk. The other guy said the tires won’t handle it. I’m not looking for anything above the rtr performance. I already have a 18 tooth in it. I was only gonna run it ever on 6s
