Outcast Got a question
Haris88
Outcast 6s
I’m shimming my front diff, should I put 2 shimms in one side or one on each side ? DC80D6B5-F278-4A83-87E3-748ECBBA776F.jpeg
JvG
Everything is relative
The Netherlands
BigRock 4x4, Kraton 6s, Typhon 6s
I’m shimming my front diff, should I put 2 shimms in one side or one on each side ? View attachment 82771
Only on the side of the gear (left in your pic).
You do this to set the mesh between the ring and input gear, so with the shimms you can set the mesh a little tighter if needed.
Haris88
Outcast 6s
But it is good to have it tight right? Because if not it may skip
olds97_lss
Bash Break Repeat!
Dekalb, IL
It's best to do it when dry (no grease), then it's less of a mess and you can feel the gear lash better. You don't want 0 lash. There should be a just a hair of play when you hold the pinion stationary and rock the ring gear back and forth. If you run it tight, it will put excess strain on your bearings, then they will die quickly, which will then likely cause you to fry the ring/pinion before you catch it.
Haris88
Outcast 6s
I just put 1 extra, so there are 2 shimms
Create account
Log in
