I thought a dedicated thread may help people looking for this mod.
After getting my hand on a reasonable priced 4S Tower2Tower center brace (you need a 20cm one) I went ahead and installed it on my Granite but noticed that a modification is needed to keep the mounts in place - 3d printing to the rescue!!
Well so I thought at least, only printed ready made models before but I tried to get it done and after 7 revisions I had a working prototype.
Its designed for 2cm/20mm in height to accommodate rear and front gaps - my rear was 1.3cm/13mm with front 1.7cm/17mm - so you can take the model and just push it through the build-plate in your slicer until you got your desired height or you can print it as is and Dremel it to shape both works fine.
Once installed they look like this
Front:
Rear
and here the spacer itself (rendered)
I have uploaded it to Thingiverse: https://www.thingiverse.com/thing:4133110 in case someone else would like to use it.
Front:
Rear
