Granite granite 4x4 driving problem
my granite 4x4 cant back up or go forward vary far on the ground out side at all but if i flip it over it can drive forward fine but it still cant back up but the breaks work fine im lost ngl
Sorry for your issue.....I don't have the most knowledge here and there are others that will reply. What comes to mine for me have you tried to rebind your rig which will force you to recalibrate.
Is this the new Granite with the STX2 radio you can download the PDF on how to do so....or whatever mode Granite version you have
Check your throttle trim. I had an issue with no reverse when I first started running my hobbywing ESC. Sat down and dialed in everything, and found out without my throttle trim set just below actually moving, the truck wouldn’t reverse....
