Jsky87
A few months ago I got a used granite mega that the guy put a vxl system in. I bought the blx slipper and motor mount. Swapped the pinion/spur to 32p. (The pinion is 32p the spur is .08 mod, but I don't think that's the problem). I ended up putting a $30 motor off eBay that looks like a hw but isn't. 3670sl/3200 kv. And I just got a hobbywing max10sct esc. Anyway the whole time I've owned this thing it eats spur gears every pack or so. 2 in 5 minutes one time. I've put almost 10 in the entire time I've owned this thing. I've bought tires, tx/Rx, batteries, charger. I have alot of $ into this thing and it's getting frustrating. The bearings seem fine, the mount isn't bent. I hold a wrench into the slipper and push it forward until it stops to set it so I think that's okay. The bearing on the slipper bolt is good. I seen diffs were only $17 on Jenny's so I replaced those, and the input gear in the rear seemed super tight, almost pushing against the housing. But I read on here that it was normal. Anyone think it could be that ? The only thing mechanically that makes sense to me is the yokes or input gear. I have a slash too and I have been setting mesh for a few months and only have a problem with this truck. I run a piece of paper through it without ripping it. Barely leaving an indentation. Any advice is appreciated. Tia
