Ndamico
Is this a thing? Teeth broken and gear cracked. Is there a better alternative? Pinion missing a tooth too. Happened on a flat landing and I wasn't on the gas or brakes when I hit. Stock motor on 4s.
Thanks
Thanks
Yeah chassis is fine. I did open a warranty claim. Spur gears seem to be hard to get. Does anyone make a stronger one, even go away from mod8?Chinaium metal, it happens.
No need to loose any sleep over..
How does the rest of the vehicle look?
Chassis still intact??
Contact HH and file a claim.
See if they will warranty it.
GPM makes a steel one, 0.8mYeah chassis is fine. I did open a warranty claim. Spur gears seem to be hard to get. Does anyone make a stronger one, even go away from mod8?
mod8
gpm ring tekno pinionIf one was to 'upgrade' the centre diff ring gear (ARA311167) and the motor pinion gear (ARA310996) in order to get something stronger than the stock steel, where would you suggest.
I searched the intraweb and found the gpm ring, but cannot find a D5 13T pinion gear from Teckno. They do make one with 14 teeth, but not in the D bore...gpm ring tekno pinion
Hmm, that’s interesting. Can use Robinson racing instead- but could a circle bore pinion work on a D motor shaft?I searched the intraweb and found the gpm ring, but cannot find a D5 13T pinion gear from Teckno. They do make one with 14 teeth, but not in the D bore...
