Do you have the Mega or the BLX?Anyone know how often you need to maintain the diffs in the granite 4x4. Also, what is the diff weight? I couldn't find it in the manual. Thanks
The Mega uses grease only and will probably never need maintained. That grease isn’t going anywhere. You would only need to repair damages. If it ain’t broke, don’t fix it.
The BLX has 10K fluid and could probably use a change every 50 packs or so. You can also take one out and change the fluid weight to experiment if you like doing that. I have 100k in mine right now just because I prefer going straight over turning on a dime.
It’s one of those things where you will find some guys do a tear down monthly just because they love to do it. I am the type that will tear it down when I feel it really needs it or if something is wrong. I’m not a sadist that loves working on or cleaning my rigs.
Can't understand if the oil of various weights is inside the actual diff or in the diff box, I mean in general.
thanks
actual diff - here from a K8S
pretty much I'd saysweet thanks!
and on the outside? any kind of grease works well?
There should be grease on the OUTSIDE of a 3S diff, but 10k fluid INSIDE the diff cup. Hope that clears it up a little. The Mega only have grease inside and out.Question: does this apply to the Typhon 3s BLX as well?
because I've opened my diff box and there's grease in there (what kind of grease is that, if I ever need to clean/replace it?)
thanks
