Yes it is a stock servo and I have had it for a couple of yearsDo you have stock servo in it how long have you had the rc for
Yea check the screw that the steering bell crank is attached to the servo rod
Yea id check the servo saver and rod then screws in front end just try to eliminate everything before possibly having to replace servo i had a similar problem with my stock servo it only worked perfectly for one side then just replaced it been good ever sinceYes it is a stock servo and I have had it for a couple of years
