AimlessRC
- Granite
Current setup:
2019 Granite 4x4 BLX 3s
Stock shocks
Front 60wt(810cst) tallest spacer
Rear 50wt(710cst) smallest spacer
Rear diff 15k cst
Front diff 30k cst
Stock 15t pinion
Hot Racing balls in all pivots and shocks
Hot Racing rear driveshafts.
.5mm washers behind hexes
20kg servo w/stock servo saver
Slipper 2 turns out
Punch 1
Trim 100%
Re-calibrated esc
Stock tires, vented, plugged rims
Undesirable Characteristics (clay, grass, asphalt):
Too grippy in corners with ANY throttle. It would rather flip over than turn on power. Let off the power and it turns on a dime, but cocks inside rear wheel, so on-power mid corner tends to diff out and balloon.
Undesireable Characteristics (dirt, gravel, jumps):
Front bottoms out on larger jumps.
Truck is unpredictable in 90 degree turns, sometimes turns in perfectly, sometimes oversteers, sometimes understeers.
I tend to run indoor clay and outdoor dirt in the same day. My guess is a lot of my problem is... well that its a Granite... but all joking aside... tires?
I feel like bumping up to 70 or 80wt in the front shocks may help the cocking a rear wheel and bottoming out... and maybe running even thinner oil in the rear diff would help on-power turn-in?
I know this is hard to diagnose and articulate without handing someone a transmitter and say "have at it."
I feel the truck is 90% there on any track I run on... just slightly more inconsistent on dirt.
Any tips?
Stock shocks
Rear diff 15k cst
Front diff 30k cst
Stock 15t pinion
Slipper 2 turns out
Punch 1
Trim 100%
Re-calibrated esc
Any tips?
