I just did the arms,tie rods shock tower, shocks. The truck drives totally different for the good. All the rest is kraton v1. My esc,motor,motor plate and diffs have been upgraded.Just want a list of parts to need thank you also as real as it can be to the real kraton
So thats all i need because i looked at the exploded view and it says i have to spend 250 dollars on just plastic partsI just did the arms,tie rods shock tower, shocks. The truck drives totally different for the good. All the rest is kraton v1. My esc,motor,motor plate and diffs have been upgraded.
Welcome to the forum dude!!
ok thanksJust jump on jennys rc buy the a arms, drive shafts, hubs, turnbuckles and camber links from the Kraton 4s or Outcast 4s and either the Copperhead LP or the Backflip LP tires. Not sure how much it is going to cost but that is literally going to be your cheapest option.
Idk if the driveshafts come with the wheel hexes and hex nuts but you need those too.ok thanks
check out tomley rc granite wide stance vid, crazyI looked i to just doing the kraton arms/axles/hubs etc to give the big rock the wide stance.
Even after looking up the parts from breakers on ebay the cost was WAY up there.. like 245$. You'd need the chassis (which is harder to find and more expensive) motor mount body and bumpers still...
Best bet if you want the kraton is just buy the kraton. Keep or sell the big rock if you need to/want to to offset the cost.
Welcome to the forum btw!
