bicketybam
Back from vacation!
- New Milford, CT
- BigRock 4x4
- Granite
- Infraction
- Kraton 8S
- Kraton 6s
- Kraton 4s
- Mojave
- Notorious
- Talion
- Typhon 6s
Most of the regulars in this section know me and my build by now. I went through a lot of trial and error to get my Granite to where it is today. I tried 3 ESC/motor combos:
Castle SW4/1406-4600Kv-maginal on 2s, no good on 3s (massive heat issues)
Castle Mamba X/1410-3800Kv - good on 2s, thermal shutdown on 3s
Castle MambaX/1512-2650Kv - current set up.
I also went through numerous slipper clutch/spur gear designs:
Stock spur and pinion - actually held up on the 1406-4600Kv motor with 2s
Yeti conversion 17t/56t 32p - no issues, but insanely fast on on the 1410-3800Kv motor (53 mph!).
Custom dual slipper hub with Arrma AR310782 57T 32p Spur with 11t, 13t and 17t pinions (current set up)
I have done more HD input gear mods than I care to remember, lol. I upgraded the steering servo to a waterproof Savox 0231MG. I also bought Traxxas 12mm wheel adapters and I run Pro-Line Trenchers.
I have finally dialed everything in to where I have a 1/10 scale beast of a MT. The 1512 Castle motor runs cool enough and the 17/57 32p gearing is perfect for 3s. I need to run some serious punch control so I don't destroy the diff pinion gears and I lowered the braking strength to 40% (again to save the diff pinions).
So this brings me to the last area I want to address: shocks. I haven't really had an issue with the stock shocks but as I push the limits further and further I feel like I need a good set of aluminum shocks to absorb the punishment I am starting to dish out (skate park jumps 25+ feet high). I want something I can just order and screw into place. I don't want to make spacers, etc. Just plug and go. Give me your recommendations and preferably a link to order them. Once I have a decent set of shocks I feel like I will have the ultimate Xtreme 1/10 Granite 4x4! Thanks!
