Help needid for fixing a problem
Speeddevil
Nieuwegein utreg
  1. Outcast 8s
Hello everybody.
Is have upload 2 pictures becouse i cant upload a video.
The problem is:
The front right arm hase to much clearance on the lower arm. On the picture you can see how much.
The left arm does not have clearance.
Is there anyone who knowes what the problem is and how i can fix it??
THANKS FOR YOUR TIME!!
Yours will be red. Tighten this nut. DO NOT OVER TIGHTEN you only need to tighten it to remove the slop.
If yours is an 8s, the nuts will be black plastic, not red.
Good luck
Thanks i have a round hex screw there and that one is already tightend. But i have stil the clearence...
You need to take it apart and see what is wrong. You may have a cracked steering hub, a broken pivot ball, or the threaded end of the pivot ball driven into the arm. Take it apart.
He says he has a round hex in there. I think he’s seeing the pillow ball and missing the pillow ball nut...
Sounds like you are right. Can’t imagine that much slop with the nut still on.
