Yes, you can make it work. Not the ideal fit because of slight bigger diameter motor but if you want to keep some extra cooling and oem look.
You can see from the last picture what i took against light that where it is not touching motor, but most part it does.
An the motor is new Hobbywing 4000kv 3665 G3 sensored.
For the fan i will run power from receiver with servo extension wire.
