could be I would take it out and strip it to make sureJust put a new 2400kv motor with a hot racing slipping clutch in my Arrma big rock and ran for like not even 5 minutes and started to smell like burning. Could it be the motor went bad
No I don’t know the motor temp but motor wasnt hot when it happened.Do you know your motor temps? Your slipper is probably loose or installed incorrectly.
There is play between the pinion and spurThere should be a slight bit of play in your gear mesh between the pinion and spur. If this is too tight, it will overheat your motor.
which bigrock? 6s or crew cabNo I don’t know the motor temp but motor wasnt hot when it happened.
3s crew cab but I have 120 esc with a 2400kvwhich bigrock? 6s or crew cab
Esc and servo are fine motor smells like it burnt but it didn’t start smoking at allTake the motor out and smell it. If it let any smoke out, it'll smell like it. If it's faint, or smells fine, move on to the ESC, then the servo. If something burnt, you'll know it.
was just making sure you weren't talking about a 6s where the issue would be obvious.3s crew cab but I have 120 esc with a 2400kv
Pinion gear on motor turns smoothsMake sure gears are turning smoothly, no binding.
