Hot Racing AON126X01 Battery tray
Harriot10
Speed runner with a learner’s permit 🤣
Maryland
  1. BigRock 4x4
  2. Felony
  3. Granite
  4. Infraction
  5. Kraton 8S
  6. Kraton 6s
  7. Kraton EXB
  8. Outcast 6s
  9. Typhon 6s
Trying to install this HR battery tray in my Typhon, but I'm having trouble mounting the receiver box. Hopefully it's something simple I'm missing! Receiver box ARA320604 does not mount without mods or bracket removal. :unsure: Should I be using a different receiver box or mount the box like the photo below??? This thing is perfect for holding large batteries!
Anyone running the HR aluminum tray please comment and share photos. Thanks!
https://hot-racing.com/?partnumber=AON126X01;c=928
Are you missing this piece?
The newer receiver box doesn't use that piece. That's why I asked if I should use a different box. The HR tray comes with a aluminum bracket very similar to the piece you circled. Maybe I need the box in the link below 🤷‍♂️
https://www.arrma-rc.com/part/AR320422
I have the same setup and have it set like you have except the receiverbox is screwed under the battery tray sandwiched between it and the body.
that tray one the best additions for a typhon.
e: Just use a knife to make room to fit the tray over.
I have spares of those as I upgrade all mine to the EXB box for larger receivers. I can mail you one.
Thanks JD! I actually just called my LHS and they're holding me one. I appreciate the offer brother!
Done! Minor mods, gotta love a dremel!👍🏼
Spoke too soon. That dam tray isn’t designed for the newer chassis. Holes don’t line up!🤬 Smh! Should of knew better HR 👎🏼
Got the receiver box figured out. Did you have issues with mounting to the chassis? It seems like the holes don’t match up!🤦🏻
It was real late here when I wrote that so didn't notice you're running a newer chassis, I have the v4 and it was straight bolt on.
It's just aluminum on the chassis tho so why not make hole or two, wouldn't be that hard.
I guess I’ll be looking for a V4 chassis. Just odd the HR site says the tray will replace AR320351 and that’s what tray I have! 🤷🏻‍♂️
