Big Rock HotRacing motor mount
dziugas1998
  1. BigRock 4x4
  2. Outcast 6s
Hello.
I just got hot racing Motor Mount to use my 18T pinion and I am wondering. Won't these screws move after hard bashing? I mean they can slide or something.
On stock motor mount there was a fixed hole in case of loose screw, nothing will happen.
Also, I did these upgrades to my truck:
Svox sw0231mg SERVO
Hot Racing Pivot Balls
Hot Racing Motor Mount
Slipper Clutch from 4s (Still not in use)
Cheap HSP Shocks (Waiting for arriving)
What else should I upgrade?
Hello.
Svox sw0231mg SERVO
Put some loctite on the screws and put them in as tight as you can!! I’ve had no problems so far doing this.
I put Loctite before and now I almost fiddlesticked up that motor hole, it really stuck with Loctite inside , it was really hard to screw in...I am afraid to put more Loctite.
Screws will be fine with some blue loctite. You will want RPM arms too
Forgot to mention, I have Front and Rear RPM arms.
Arms and turnbuckle form a typhon 3s.
Better servosaver
What is the difference Big Rocks vs Typhon 3s turnbuckles? Last week I ordered the Big Rocks turnbuckle set :/
Which ServoSaver do you recommend?
Typhon has longer turnbuckles, the arms will not work without those turnbuckles.
The brcc gets wider and much more stable.
I have also used fishing wire on my tires to stop them ballooning, works good ?
I have no experience/ recommend on servosaver.
It's stupid but right now I'm driving without servosaver
I am thinking to wrap my tires with fishing wire. Won't it cut my tires? Can I see photo please how you made it? Did it improve handling?
Can I see your setup without servosave, please?
The wire works good for me ? :)
Can't get any pics on the servo, but I'll also not recommend you driving without the saver
I didn't understand what do you mean servo saver.
I my opinion servo saver is this: https://prnt.sc/r70pq2 .Am I right? If yes, ofc I have this in my truck.
Btw, how you make these tires with fishing wire? Glued or what?
That's the servosaver yes, the Arrma one isn't the best.
Used super glue on the fishing wires :)
