Badmofreaker
- Typhon 6s
I decided to build a high powered,low rpm setup for speed runs. It's almost done, should be ready for the weekend. Tell me what you guys think.
Sorry but they beat you to a dual motor limitles….Wow. DUAL 2028?
Didn't say it was the first!Sorry but they beat you to a dual motor limitles….
ThanksSweet!!
I think it was a power hobbies, I bought 2 from different manufacturers and were the same thing. As far as the wing,the bottom plate helps stiffen up the body,and so far runs really straight pass after pass from 158 to 160,don't know what I'm going to hit now,Looks good, FC100 body is great and I like your wing although you may not want both elements across. I like that you addressed the side body flex issues.
I'd recommend truing down the foams some.
Which model Gyro is that one? I don't recognize it. I have the Futaba for my 200+ build.
Thanks
Let me guess,,,,49t pinion on car??????do you know max pinion on pps mount??I decided to build a high powered,low rpm setup for speed runs. It's almost done, should be ready for the weekend. Tell me what you guys think.
Yeah, me too,I have to see how it handles before I open it up with having a different chassis and being 6 lbs heavierJust thinking about aero drag for the wing deal.
You could also remove the rubber body pin tethers to reduce the drag some.
Looking forward to seeing some videos of it running!
Very true!Didn't say it was the first!
Thank youTalk about craming stuff in lol!! That's crazy. Nice build
True.. true. But it wont be the last!Didn't say it was the first!
I came to the realization that there's a thing called too much power! It's just breaking stuff easily every time I try to get past 70 percent throttle. So I took the 1100's out and put in 2400's and new body and will try again.I decided to build a high powered,low rpm setup for speed runs. It's almost done, should be ready for the weekend. Tell me what you guys think.
Got a link to a tire truer? All the one's I can find are ridiculously expensive. I need to shave them down because my droop screw tabs are screaming for dear life trying to get my rife height down.I'd recommend truing down the foams some.
Nope they are stupid expensive for what they are....Got a link to a tire truer? All the one's I can find are ridiculously expensive. I need to shave them down because my droop screw tabs are screaming for dear life trying to get my rife height down.
Let me guess,kept breaking stuff from the spool back??rear center shaft,cups ,ring&pinion, diff houseing..I came to the realization that there's a thing called too much power! It's just breaking stuff easily every time I try to get past 70 percent throttle. So I took the 1100's out and put in 2400's and new body and will try again.
