- Granite
The new slipper clutch assembly screw is longer. I think it might be a problem if you're using the older longer input gear. The old slipper maintenance set is still available. https://www.arrma-rc.com/part/AR310882 You could also just buy a M2.5 x 20mm Cap Head Screw. All the other parts are the same.
