allprofamous
- Kraton 6s
I have a kraton 6s. If I change my esc to a esc 160 will it go faster?
U will need change motor also. Or do what @Edough13 saidI have a kraton 6s. If I change my esc to a esc 160 will it go faster?
7200. 100c power hobbyNo only if you run it on 8s, 6s with a bigger esc is still 6s. You can change to a larger pinion for more speed but you'll have to watch temps as your motor and esc will run hotter. Or you can go to the 46t spur also for more speed but again rig will run hotter. Also batteries you run can make a difference what lipos are you running?
OK ya you need to either gear up for more speed which is the easiest option or try running 8s with the bigger esc but it's going to be rough on the rig running 8s.7200. 100c power hobby
ThanksOK ya you need to either gear up for more speed which is the easiest option or try running 8s with the bigger esc but it's going to be rough on the rig running 8s.
