Helps if I put the tires on right. I had fronts on back and backs on front. Oops. Runs better now.Proline MX28 Badlands have landed along with the Duratax 12mm hub adapters. Looking purty.View attachment 27727
Had some wheel rub in the front and wrecked my rod ends. ?
Do you run a set on the front AND back? I got a set for the front but the back looks narrow now?I was about to ask. Those don't look offset??
They will both rub tho even with 1/2 off set because they balloon like crazy and when u turn.. You guessed it.. Bam rubbing..
Look into HR wheel extensions I run 18mm length w/ 12mm Hexes, Had to drill out the center hole a little as there desgined for I think 5mm axels but not a huge problem.
Liquid Rc on ebay has them.
https://www.ebay.com/itm/Hot-Racing-SCX10ET01-18mm-Wheel-Hub-Extensions-with-12mm-Hex-2-Axial-Scx-Wra/262668055150?ssPageName=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
