_painter_boy_
Not done a build log before so going to bumble through it best i can
First thing for the upgrade was getting rid of all the plastic and fitting the stand alone crcu servo mount
Took a couple of hours plaining making sure its in the right place with clearance all around, needed to drill the 4 new holes for it and if you have one you'll no there all on different levels where I've placed it. Done it so its the same height as standard and same kind of position, used spacers on one side to make it level. Managed to get all 4 holes drilled in perfect position
Feels totally solid and looks good
Next will be fitting pps motor mount and crcu titanium shafts
