Kraton 16T pinion
arkansasturbo
  1. Kraton 4s
I can get the pinion on the motor, but I cannot get it through the mesh adjustment slotted hole so that I can set it in the car. Any tips?
Apply heat and use a quality 2.5mm hex driver, I put the bottom of the chassis directly on a table for maximum torque transfer. Variation in tires/suspension when unloading and loading that clamp will most certainly end up in a stripped hex. If you already stripped it, tap in a 7/64" hex or dremel a slot for flathead screwdriver. Again, the factory uses threadlock so heat is your friend.
what a mesh adjustment slotted hole
The slotted holes for adjusting the mesh of the pinion and spur.
Already had it out, the question was how to get it back in. I wasn't thinking straight, I got the car up and running now. Thanks though!
These slotted holes?
