Barmaleus
Hi all!
As I continue looking at the K4s internals and topping up fluids to make its very first run, I disassemble the center diff today.
So far, there are few things I don't understand (new to RC).
1. When I move the center diff, it kinda has a little play. Is this normal or should it be tight? Here is a video:
2. When the whole construction is on a horizontal surface, it is not fully aligned. Is it fine as is? Here is a video:
3. There is no grease whatsoever between the center diff and the motor pinion. Is this how it should be?
Thank you!
Thank you!
