Kraton 4s V2 center driveshaft issue
arkansasturbo
  1. Kraton 4s
The center driveshaft in my 4s has failed, specifically the rear section has twisted itself apart just ahead of the bearing support. I ordered replacement part ARA311065 and when I went to install I noticed it is visibly different and about an inch shorter than my old driveshaft. AR310881 fits into the new (wrong?) shaft but is not recessed into the shaft like it was on the old broken shaft.
I can't imagine my exploded view diagram that came with the car being wrong, but I have scoured it to my wits end. Am I missing something critical here?
Here are some photos.
I did get 4 pieces. The rear section, a short front section, a long front section, and a spring.
Your driveshaft is supposed to look like this. Yours has welded the two pieces together.
If your running where sticks,wood chips small rocks all over. Check your truck from time to time to make sure nothing has wedged itself in the center driveshaft. That will grind down the driveshaft and cause that break.
I didn't realize that the tail of the rear section was in fact 2 different pieces. I was able to separate it. Final question, when I place the "sheath" up against the new shaft, it doesn't snap into place. There's no lip for it to ride on on the new piece. Is this okay?
They wear out fast.
