Ok so after i get my kraton 6s for xmas etc should i bother buying a 4s battery and learning to drive it slower like that or just buy a 6s battery and throttle it slower?
If your concerned about learning to drive with too much power, but don't want to buy 4s then a 6s battery, you could just buy the 6s and turn down the punch setting and watch your speed. Punch setting changes the initial power hit but not the max speed. If the Kraton is the current model and comes with the Spektrum Tx it will also have a throttle limiter dial on the controller you can use to restrict the throttle.
If budget is not an issue buy the 4s first.
Lol. Do not use the throttle limiter dial on the stx2.
The stx2 is wonky on the 6s rig. On 50/75 you don't get any reverse. And very little break.Why?
I ended up getting 2 6s packs. I'm pretty sure throttle control is the key. Worse comes to worse i can drop it to 75%
yeah im sure i can feather the trigger .. I mean ive been shooting guns for yearsI'm sure you will be fine.. its really not that crazy as long as you have some dexterity in your trigger finger and don't treat it like a button.
