Hi all, fairly new to the hobby. I recently purchased my first rc car, a kraton 8S. I've had some issues that I believe are related to my batteries and am looking for some guidance.
I am running dual gensacearespammers Bashers 4S 11000 mAh batteries. When I first got the car a couple months ago I would get 40-45 minutes of run time on my batteries. Now I'm getting about half that, around 20 minutes. This is on an easy light run, if I'm running it harder/faster in an open field or lot I'm getting only 5-7 minutes.
When I plug my batteries into my Protek Prodigy 66 charger I'm seeing that one battery is much lower than the other. I've attached some pictures but one battery is around 13.7V and the other one is 14.85V. I then run a balanced charge and they both take about the same time to charge and reach capacity and they finish right around 15V.
To me it seems like only one battery is being depleted and the car shuts down when the one battery reaches a low voltage. Both batteries are less than two months old and appear to be in good condition.
My question is what would cause only one battery to drain while running the truck? Is this an issue with the battery or something else with the motor, esc, or battery connection cables? Curious if anybody else has had this issue and what the fix was?
I appreciate any info.
Thanks!
-Paul
Thanks!
-Paul
