Kraton 8s battery capacity choice
DMDUK
Kent, England
  1. Kraton 8S
  3. Typhon TLR
Morning,
What capacity batteries do you run in you 8s Kraton?
Thanks.
David
The more the merrier with that 30+ pounder platform. It is an amp ho with that weight.
I don't believe 5k mah packs cuts it for most with the 8s.
My guess is 8k mah or more. Costly for this capacity. Is what it is.
Much ultimately depends how you geared yours.
Larger capacity lipos also add much more weight. So that may be subjective up to a point.
An amp ho!!! 🤣 Brilliant.
I have the new Kraton on pre-order so working out which batts to buy.
Thanks for the reply.
I’d say 8000 mAh or bigger otherwise they won’t last long…
Ive noticed that my 4s1p packs are much happier than when I run my 4s2p packs. That being said I like my CNHL 9500s they have no issues.
