I have a kraton 8s and the servo mount only holds the servo with 3 screws. Is this a older model because when I look up the part it has 4 screws?
PicturesI have a kraton 8s and the servo mount only holds the servo with 3 screws. Is this an older model because when I look up the part it has 4 screws?
Did you pick this truck up used? The v1 Kraton 8s RTR came with a S905 1/6 scale servo.That is a replacement servo, 1/5 scale, installed in a 1/6 scale mount. Someone shaved the mount to fit that servo. That's why you only have 3 screw holes. To remedy, you need ARA320553 servo mount set. It comes with both sized adapters for 1/5 and 1/6 scale servos.
Yours had 4 screws, until someone modified it to fit the 1/5 servo. The screw above the missing one is in a new hole that the previous owner had to drill out. Ech adapter size does indeed utilize 4 screws to hold the respective sized servos.I have a kraton 8s and the servo mount only holds the servo with 3 screws. Is this a older model because when I look up the part it has 4 screws?
You bet! FWIW, you could very well just keep on running as is with the servo mount.Yes I did buy it used. Thanks for the info! Other that that it’s a pretty nice truck! Thought it might be version 1.5 because it has that metal extra brace in the rear and the red braces that meet in the middle and not across whole truck.
Thanks again!
