I run a hobbystar 980kv. 30/39 xlx2 combo. Earplug the center. My most responsive setup. The 980 is a nice sweet spot. Torque of the 800 and the rpm of the 1100. Plus they don't cost an arm and a leg.
You're definitely faster than 48 mph with that setup. I have the same in my k8s geared 31/39 and it's definitely capable of hitting at least 60+ mphI run an Outcast 8s with castle 2028 1100kv on 32/39 gearing and it ripped the stock backflip tires loose from the rear wheels running on grass. It wheelies real well too. Does about 48mph top end and will wheelie at speed on demand. Never got above 129 f @ 86 ambient temp.
Right now I can't keep the front wheels on the ground @ full throttle to max it out. Still need to tweak it a bit. Have punch set at 20%. Ordered belted tires.You're definitely faster than 48 mph with that setup. I have the same in my k8s geared 31/39 and it's definitely capable of hitting at least 60+ mph
