landbruiser69
New Member
Hey guys, Purchased the Castle 20 series 1100KV 2028 with the XLX2. Looking for the correct motor mount for the 20 series motor. Purchased the PracticalProto 30mm Motor Insert for Arrma Kraton 8s. Hoping this is correct.. any advice???
Also need advice on the correct gear to get for the 8MM shaft...
Also, anyone running the NSDRC V2 servo? Curious about adaption to the servo saver and whether or not you all have had issues with gears stripping. Thanks in advance.
