so i bought the kraton 8s exb. put a hobbywing 1100kv max5. running 30/47 gearing. 20mill center 1mill front 500k rear. finished building the car took it out for first time within 15 minutes i heard crunchy noises. took it apart sun gear and pinion had bent teeth. everyone said upgrade to aluminum diff cover so i went with vitavon. took internals out of old diff moved to new case with new sun and new pinion. within 10-15 crunchy noise came back. opened it back up could see no damage but my diff was completely locked up this time. so i took a deep dive got a vitavon bulkhead a vitavon prebuild diff case with upgraded outdrive cups and shafts. made sure all the screws were tight put it in took it out. ran for 20 minutes fine on the road. took it to my front yard before turning it off, took a small turn and gave it about 30-40% throttle coming out of the turn crunchy noise! spider gears are gone now. the original diffs i shimmed etc to no end. the new prebuilt diff with the large outdrive cups etc cant use shims they arent big enough and it honestly had zero play in the diff. i could launch this car on full throttle and the diff will be absolutely fine. take and anything more then 30% throttle my diff gives up somewhere. i've been talking to people all over facebook and nobody really has any idea's why its doing this.
ive never ever had this issue with any cars (been doing it for 10 years) i've done diffs in my savage nitro my savage flux typhoon rovan baja xmaxx list goes on. never ever had any issues i can not for the life of me figure out why this car is exploding its diffs everytime i go out and im losing my mind and my wallet at this point.
