u189961
- Kraton 8S
Hi Everyone,
I noticed today that the rear driveshaft has a slight bend to it, saw it when I was cleaning her up and was rolling it forward. I've only taken her out 2 times, no crashes or flips, it does have a 23t pinion and punch at 5. Maybe I'll go easy on hard accelerations on asphalt, too much torque and grip causing it to bend?
I already ordered a replacement but was wondering of the easiest way to remove the rear driveshaft? I couldn't find any videos, mostly diff rebuilds. It seems I would have to undo the rear diff cover, pull the diff out, remove large C clip towards to the front of the rear diff and pull the rear driveshaft through the exposed rear diff area? Or would I have to remove the entire center diff assembly ?
Thank you!
Thank you!
