This chassis is made using 4 mm 7075-t6 aircraft grade aluminum and anodized clear. On the advise of Of our test team We have redesigned the
rear section of the chassis and added 20 mm more material to cut down on chassis flex. this material is time tested to provide much more regidity
to the chassis. We have also added steel droop steel stops as this is a major wear point of any chassis on the market.
this chassis is made to use the stock bumper. We have machined the front down to 3mm to accept the stock bumper. It is a little hard to fit , so if you leave the front bulkhead loose and angle the bumper at about
30 degrees it will slide right in.
or the guys, running the aftermarket arms we have added an additional droop screw stop in the rear.
FITS
KRATON V1,V2,V3,V4 CHASSIS
TALION V1,2
FITS
TALION V1,2
